necessary gauges
Old 06-27-2007, 07:23 PM
blake2500's Avatar
necessary gauges
what gauges are a necessity for a near stock truck other than fuel pressure, and where can i get them?
i would like to go ahead and get the parts i need as inexpensive as possible. i have no mods other than muffler delete, but want to make sure nothing fails on my truck.
all suggestions would be great since i dont know much about brands for gauges.
Old 06-27-2007, 07:35 PM
wcbcruzer's Avatar
None more are necessary... Boost and pyro if you want to be cool. Maybe a trans temp. gauge even. Autometer, isspro, di-pricol, etc. All good. Ebay or www.genosgarage.com, or www.dieselmanor.com.
Old 06-27-2007, 07:47 PM
slim51015's Avatar
If your towing, tran. temp.
Old 06-27-2007, 07:51 PM
blake2500's Avatar
everybody seems really worried about fuel press in 2nd gens...is it worth investing for gauges to keep tabs on it?
Old 06-27-2007, 07:57 PM
clutch1's Avatar
uhh, ya.... just on the vp44 trucks
Old 06-27-2007, 07:58 PM
wcbcruzer's Avatar
Yea fuel pressure is the only one you really need (98.5+ trucks).
Old 06-27-2007, 08:01 PM
ratat98's Avatar
I just got a fuel pressure gauge to keep tabs on the faulty fuel pumps in our 2nd gen 24 valves, and a pyrometer to make sure the turbocharger gets nice and cool before I shut the truck down...I don't really see the need for anything else
Old 06-27-2007, 08:06 PM
Ridiculous's Avatar
if you have an auto tranny, which i see you do, i'd get one of those thrown on there too.
Old 06-27-2007, 08:10 PM
Destination's Avatar
boost,pyro,fuel pressure definitely
Old 06-27-2007, 10:03 PM
displacedtexan's Avatar
I don't think boost is necessary at all on a stock truck. Could occasionally be nice for troubleshooting, but other that not needed.
I would say mechanical FP, then a Pyro, and Tranny Temp.
Old 06-28-2007, 12:28 AM
HOHN's Avatar
No need to spend big bucks on a FP guage. After monkeying around with different options, I've found a cheap glycerin-filled mechanical gauge from Jeg's has worked best. $20!
Old 06-28-2007, 07:34 AM
blake2500's Avatar
awesome hohn, ill look into it today, im probably just going to do something cheap like that and mount it on the steering column.
i dont plan to do anything else for a while to the truck so i just want to keep tabs on the fuel press so i dont kill the pump
i dont need the pyro if im just daily driving, nothing extreme, and give the necessary cool down time before i shut down the engine, right?
....anyone correct me if im wrong here
Old 06-28-2007, 01:11 PM
haloman's Avatar
This is good news... could I get a link please?
Old 06-28-2007, 01:18 PM
HOHN's Avatar
My bad: mine was $17.99
http://www.jegs.com/webapp/wcs/store...63500_-1_10339
Just plumb it with some grease gun hose. These gauges are 1/8" NPT male on the back-- really easy to connect. The liquid filling dampens vibrations, as VP44s tends to make mechanical FP guages pretty noisy (hence, some use a "snubber" which is unnecessay with these cheapo gauges.)
If you're feeling really clever, you'll notice that these gauges are 1.5"-- which is almost exactly the same size as the tweeter cutout on the pillar. You can mount one of these in the tweeter spot and still keep your other gauge pods available. Hence, with a 3-gauge pod w/ tweeter, you can mount FOUR gauges!!
It worked well for me, and if they gauge craps out, it's very cheap and easy to replace.
JMO
Old 06-28-2007, 01:29 PM
haloman's Avatar
So I could get the two gauge mount with tweeter so I can get pryo and boost?
Then I just get a banjo bolt? and plumb it with some grease gun hose from my local farm store? and would I need anything extra for my low fuel pressure sensor/ light?
TIA
Quick Reply: necessary gauges
