mystery switch ?????????
Old 10-24-2006 | 11:03 AM
inline6power's Avatar
installed it yesterday and it works beautifully . only question is after the install i got the check engine light. just wondering if this is normal or did i do something wrong.
Old 10-24-2006 | 11:11 AM
Marine's Avatar
I have the diagram in my gallery. Double check and see if it is the same, or if you left something out.
Old 10-24-2006 | 12:38 PM
Mcmopar's Avatar
Using a lock up switch does store codes in the computer, but usually does not illuminate the CEL. Go have your codes checked.
Old 10-24-2006 | 01:25 PM
CSAGrey1's Avatar
Don't suppose you happen to know what code that would be do you?
Old 10-24-2006 | 02:03 PM
Mcmopar's Avatar
0743 T/C clutch circuit
1765 Transmission 12 Volt supply relay
These two are set because you need to replace the relay with a jumper, and the truck "knows" the the t/c should be unlocked at times when it is not.
Old 10-26-2006 | 08:02 PM
CSAGrey1's Avatar
clear them and I doubt they come back. Mine through the same codes when I first installed my switch and they havent come back since
cowboykilla235
02-17-2013 03:02 PM
hoot
03-14-2011 04:43 AM
SPLnut
12-31-2007 11:27 AM
whazzup
12-16-2003 09:09 PM
Mostwanted
05-28-2003 05:27 PM
Quick Reply: mystery switch ?????????
