My thoughts on II HRVP44 ... long
Old 06-10-2007 | 10:09 PM
juicedbusa02's Avatar
Talking My thoughts on II HRVP44 ... long
I have looked around on here for a long time and have finally started posting a little bit ... I recently had an injection pump failure at 165K and i believe this was the original vp. when i purchased the truck with 154K i replaced the fuel filter and it would not reprime itself .. i therefore purchased the bullydog big fuel kit for my lift pump and thought all was well ... have put about 10K on the truck or so and was driving down the road and just died and would run to about 1K rpms .... so anyways ....
i had looked for hours and hours about the argument of whether or not the HRvp44 was worth the extra cash or not .. heres my personal view on it for people like me that have had a pump failure and are looking into the pump ...
I got done with the vp install on monday morning .. batteries were dead from the dealership trying to get it restarted (another story) so i replaced the batteries which have been due and took the truck for a drive.. the power feels nice nothing crazy but you can definitley feel it .. about like level 3 on a comp or j/a box.. would i buy this pump to replace a perfectly good running pump? absolutely not no way ... would i buy this pump if i was trying to make a HUGE amount of horsepower on a truck? probably not .. but if i was someone in my shoes that had a relatively stock truck that had a pump failure.. yes i feel that the amount of power gained from the hot rod pump was worth the extra money .....
the only real downside i can see to this pump is the price AND that on my auto truck when the a/c is OFF the truck has a somewhat irratic idle or lope i guess... doesnt really sound like a lope to me but i've seen it called that .. and the truck seems to idle a little higher as well ... with the a/c on .. idles just like stock ...
just thought i'd let some of the guys that were interested in this pump hear my opinion before they shelled out the extra cash .. thanks for reading
Chris
Old 06-10-2007 | 10:15 PM
BigBlue's Avatar
I'll agree with that. For the big hp guys with major fueling boxes the SO pump will work perfectly and go just as high as a HRVP pump. For the guys who want just a little bump in power the HRVP would work. Glad you enjoy yours. And yes the idle thing is a down side to the HRVP.
Old 06-11-2007 | 03:10 AM
Ph4tty's Avatar
Is there a change in idle rpms with the ac on/off? I get the lope when rpms drop down in the low 700 range.
Good post man. Are you going to tap the new pump??
Old 06-11-2007 | 11:00 AM
yeah there is a slight change .. seems to idle a little higher with the a/c off .. and has a kinda lope to it then ... but with the a/c on it idles about prob 800 or so and idles just like stock... it doesnt really bother me kinda sounds cool really haha ....
am i going to tap the pump..... i dont know really ... its still up in the air ... i just dont want to have to buy another one... and i think i might be doing a lift/wheels/tires soon so most of my money will go to that ... 6 tires !! haha thanks guys
Chris
Old 06-11-2007 | 12:25 PM
RJW922's Avatar
I just had my 44 replaced with a unit from Blue Chip Diesel. I went with the
"X" pump, it was about the same price as the Cummins pump. Blue Chip claimed an increase in fuel mileage and H.P. I am impressed!!!, I put on over 300 miles this weekend and ended with a solid 20 mpg. Thats up 2.5 mpg over what it would normally do under the same conditions.The extra kick is nice also.
Old 06-14-2007 | 10:47 PM
Tate's Avatar
If you have a dying pump, a fresh one would/could bring extra power and mileage. I'm suspicious of the Blue Chip stuff myself.
As for the HRVP, it runs nice, but mine has that crappy idle, sounds like it still fuels a bit while coasting in gear, and surges at around 1500 rpm with a light to no oad on it when warm. If its warm, and I bring it to 1500rpm while in neutral, the truck will start to rock. If I do it when its cold, nice and smooth. If I were gonna replace a fried VP with another, I'd do it with a plain jane SO pump instead of the HRVP.
Old 06-15-2007 | 12:05 AM
ratsun's Avatar
Just land your 887 on and you will finally be happy
OOppps did I type that out loud
OK I will go back to the 12V forum now
Old 06-15-2007 | 12:27 AM
dodgediesel's Avatar
I'm with you on that one Tate, my idle is terrible ... I will put on a SO when this HRVP gives up...
Old 06-15-2007 | 01:36 AM
Tate's Avatar
I'm working on it bud. Hopefully in 2 weeks I'll get to start wrenching on it.
Old 06-15-2007 | 12:08 PM
Tate, what did you end up getting for a turbo?
Old 06-15-2007 | 02:58 PM
Ground Shaker's Avatar
I have had way to many complaints about the idle and sorta stumbled across something that fixed it. I had a HRVP on my truck form Dan and with .093 lines and .120 connector tubes I didn't notice any lopy idle what so ever. Patty and them told me many a time when talking with Dan that I would have this crazy cammed up sound to the truck which didn't bother me, in fact I wanted it, however when I put the lines, 8x18 injectors, tubes and pump on, to my suprise it ran smooth no matter what I did to it. 2 month later one of my lines broke and I didn't have a replacement on hand so I put the stock lines back on and wow did it idle crazy. I could make a milkshake with how bad this thing idled. So I started playing around with it. I found for my truck with the fuel system I had that lines really effected the idle, however, on other guys trucks of less hp, if you changed the connector tubes out, it changed the idle. We found if there is just a slight idle when warm, the .084 lines should take care of it it the same connector tubes. I had to go up to the .093 lines and so to see any change. I have worked with quick a few trucks and think I have solved the idle issue for my guys but again it take time figure a few little details out. Hope this helps some of you guys.
Old 06-15-2007 | 03:28 PM
Tate's Avatar
SPS62. Doug had a deal on one, otherwise I would've gone with the HTT71 turbo. I wanted the stainless housing, but for the extra cash, we both agreed that the SPS would be the better deal.
BobQ
03-14-2006 01:00 AM
singleturnout
02-20-2006 06:53 AM
Gene007
01-14-2006 09:32 PM
Terraizer
12-14-2005 08:28 AM
95ram
11-12-2005 09:45 AM
Quick Reply: My thoughts on II HRVP44 ... long
