My new turbo
My new turbo
I just ordered a super phat shaft 62 from industrial inection. Any one have one of these? How do they run? I have a drag comp, jammer 5's and 4" straight pipe and cold air intake. How will this run on my truck you think? Thanks Skyler
I just put mine on about 2 weeks ago.
It all depends on which exhaust housing you got and what you expect from it. I have the 14cm and it has a slight lag, but once it lights it comes on smooth and strong (starts around 1400RPM, but really takes off around 1800-1900RPM). It really shines right around 40-45psi. I have yet to get my EGT's over 1200* with the TST on #9 and the Smarty on SW #9 on level ground unloaded.
Towing at around 20K gross I leave the TST off and on slight grades EGT's can approach 1300*. I have yet to see 1400* even for a split second, but I haven't flipped the switch on the TST while towing yet.
I have jammer 5's with a drag comp and i think i'm over fuling my stock turbo cause i can hit like 1400 real real quick. I'm hoping for like 75hp. That would be good and hopfully take my temps down a bit for i can on the gas longer.
Originally Posted by mx yfz 450
What kind of horse power increase do you think i will gain from this turbo? Thanks Skyler
By release I mean you will convert smoke (unburned fuel) to HP.
From all accounts, that is a great all around turbo! Hope you got the 14cm equivalent housing on the turbine? Smaller will, IMO, got hot too quickly.
Good Luck
RJ
CumminsRedneck
02-18-2013 07:51 PM
hoot
04-16-2008 10:08 PM
kawi600
06-21-2006 06:48 AM
HOHN
28
07-06-2004 04:38 PM
