is my comp dying???
is my comp dying???
hi guys,ive had my comp on for almost a year,i run mostly 3/3.i was working out of town without the truck for 8 weeks and just got home to start my baby up,pretty cold so i plugged her in for a few hours,she started a little slow.the pyro went up to 900 instantly for 20 seconds then went down to the 300 it normally idles at,is that because the bateries were low?things were going good on the drive into town then i wanted to put it on 5/5 for some fun,seemed real slugish and no smoke,turned the comp off and it had more power with out it on,turned it back to 3/3 and there was a diference,some smoke and felt like its suposed to.then turned it to 5/1 and there seemed to be a diference,then tried 5/5 again and it was working good,do i have a bad conection?or is that a symptom of a dying comp?i heard of many dying,do they just stop working or stop working on certain levels?i thought i had a good one as its been a year working well.thanx for any help
I think they are kinda moody, mine works great but sometimes it won't turn on or off so I have to turn the truck off and restart and it works fine. Who knows why. If you do keep having trouble contact Edge, they will help you out.
On occasion, my pyro will "pulse" up to some wierd temp and then drop back down just as fast to a normal temp.
It only happens on real cold mornings and I think it has something to do with the grid heater coming on right after the truck starts up. It did it once to me when I tried to open the window (power) immediately after the truck started.
Might have something to do with a low voltage situation right after the truck starts and maybe the pyro driver is compensating. Beats me anyways. I'm not sure about the Comp being involved in this. I run an EZ and it will do it when it's either on or off.
It's done it off and on since day one (4 years) and I run both pre and post pyro's and they both do it. I don't worry about it anymore.
Jeff
Jeff
duallydave
09-16-2006 12:27 AM
James Lucas
14
08-29-2003 11:24 AM
hellotbone
07-12-2003 12:58 AM
hellotbone
18
05-16-2003 04:40 PM
