Multi-Function Stick
I couldn't leave well enough alone. I had to made a change to the ol' truck again.
I've added more controls to my transmission stick... Check it out...
I've got two sets of driving lights and each one has a purpose. Like the 55W bulbs are my street legal set and aimed low. Then there is my 100W set that are aimed higher and used for a variety of reasons... Offroad, etc. So the top yellow switch is a two postion with a center OFF. The driving lights are activated by the trailer lights relay. (Check photo gallery)
My Jake Brake is still there... The jake switch lights up when the jake valve is closed.
Then there is the backup lights. You can force them ON without being in reverse. Great for hitching up a trailer in the dark. So the bottom switch is a standard ON/OFF switch. Oh for you guys that said my backup light wouldn't last... So far there is 10K on the roughly and not blown a bulb yet... (Check photo gallery)
All controls are easy to use with your thumb / forefinger.
Just figure I would share my ideas with the group!
floridagc
12-17-2006 05:19 PM
