Muffler removal question
Old 10-30-2003 | 06:31 PM
blackjack's Avatar
I remember as a kid when we used to take a stk muffler and ram a bar through the center untill we had a straight through hole then stick it back on the car so we sounded cool. Having never looked at my CTD muffler would I be able to do the same thing.thereby not having to take to a shop to have a pipe added.
My second muffler question is. When you go with open exaust on a gas motor you lose horsepower in the lower powerband range because of the loss of back pressure but when you start to increase air intake and raise compression you can open exaust more to increase H.P. espessially by cutting to length to produce tuned exaust for a particular powerband (rpm) range. Does the same principals apply to the CTD or do you apply a different principal because of the compression?? ???
Old 10-30-2003 | 06:42 PM
jfpointer's Avatar
Re:Muffler removal question
Well, other than just the higher compression of a diesel, it's also got a turbocharger on it. That has to have some sort of effect on any backpressure that might be present. At any rate, my understanding is that opening the exhaust on these motors doesn't have the effect that you're talking about on gassers. I'm sure someone will correct me if I'm wrong, though.
Old 10-30-2003 | 06:43 PM
VinDiesel's Avatar
Our diesels act differently mostly because of being turbo charged. In this case, the turbo applies some back pressure to the engine. You can go to a larger turbine (exhaust) housing, which will let the engine breath better, but will also cause more turbo lag.
It is generally considered best to open up the exhaust as much as practical. This will help the turbo spool a little quicker. Also reduces exhaust temperature somewhat.
Many run with no muffler at all. Others prefer a straight-through performance muffler. Somewhere around 350hp or so, you may want to go to a 4" diameter system.
Old 10-30-2003 | 06:46 PM
I think the muffler on a CTD is built a little too tough for that trick. Never hurts to try, though.
You won't lose bottom end by straight piping a turbo diesel. The more pressure drop there is across the turbine, the faster the turbine will spin. By removing the backpressure caused by the muffler and/or cat, you increase the pressure drop, which gives you faster spool up (actually helping bottom end power) and more boost. The added airflow helps keep EGT down, too. The most important thing is that it sounds beautiful. 8)
Old 10-30-2003 | 06:47 PM
dsljunkie's Avatar
Back pressure is bad JUJU on a diesel . You wont loose any hp by whacking that thing off and your truck will probably run better if you go ahead and pull the catalitic converter off as well, due to the fact that it is most likely plugged.
Im not sure about stickin a bar through through the muff to open it up but you can clean out the cat. with the "bar" method.
Scott
Old 10-30-2003 | 08:17 PM
phox_mulder's Avatar
[quote author=dsljunkie link=board=7;threadid=21756;start=0#msg203763 date=1067561249]
Scott
[/quote]
2001 didn't come with a CAT. Go ahead and remove the resonator along with the muffler (the little muffler in front of the big muffler).
I didn't but wish I would have.
Not going to bother now, as next exhaust mod will be a 4inch all the way.
phox
Jmac
09-09-2006 10:23 PM
Patrick Campbell
03-23-2005 01:29 PM
FarmBoss
11-10-2004 04:24 PM
commonrail
10-22-2004 07:47 PM
w4xtc
24
05-05-2003 04:36 PM
Quick Reply: Muffler removal question
