MPG comparison
MPG comparison
Does anyone have any numbers on the mpg of the smarty on fuel saver vs. smarty + comp if driven real soft?? Just wondering because i'd like to keep the power but fuel cost is getting crazy
Hohn, what makes you say such things? Have you noticed no more increase above those levels of pressure? I know Semi's are different, but they run over 100 psi. I know it helps with the load, but it seems the harder the tire, the lower the rolling resistance.
It's diminishing returns. Every higher PSI is less of an increase than the one before it. In other words, going from 15-20 psi is a big increase, but going from 50-55 is a small increase.
In general, yes-- the harder the tire, the less the rolling resistance. But you reach a point where more pressure won't make a tire any harder.
It's that whole diminishing returns thing..
bngcustoms
45
06-20-2009 06:55 PM
bigfish5
09-19-2006 12:56 AM
