More smoke from my juice
Old 04-21-2007 | 06:15 PM
tweeder_51's Avatar
First of all I want to say I'm not looking to black out the streets so please don't preach to me about too much smoke making diesel guys look bad. That being said I am a little disappionted with the amount of smoke I am getting out of my juice is there anything I can do to get a little more?
Old 04-21-2007 | 10:29 PM
tweeder_51's Avatar
Anyone? I already have it turned up to 5 on each sublevel of the low boost fueling.
Old 04-22-2007 | 01:01 AM
dieselrob's Avatar
You realy cant do anything to make it happen. But you can get bigger injectors, or a smarty and it will help. The more power the more smoke(if you want) there is clean power to.
Old 04-22-2007 | 02:51 AM
Big Blue24's Avatar
Start up in second and quickly shift to third and lugg it at like 1K RPM and floor it, it will smoke like no tomorrow if you have it on 5x5. Make sure you tapped the right wire on the IP. If not, levels 2-5 will feel almost identical. If you correctly tapped the wire as per edge instructions and then follow my instructions, you will have a lot of smoke. You can also add a quart of TC 3 two cycle oil from Walmart to each fill up and you will get more smoke, and added lubrication supposedly. And if you want to smoke like a freight train, add some dirty running Jammer 5 nozzle's, you will never be able to run smoke free without turbo upgrade with those nozzles. I just saw some on Ebay today for cheap!!! like $215.
TDRattler
07-12-2008 07:42 PM
BlackSheep5
11-27-2006 07:52 PM
razor6
02-08-2006 10:54 PM
razor6
01-22-2006 05:57 PM
Quick Reply: More smoke from my juice
