More power! What next?
As you can see in my signature I have a smarty and rv275 injectors. The trany has been done. I want to stay at or under 400HP. What should I do? Maybe a box? better injectors? I do want to stay with the stock turbo if possible. I only tow once in a while, (snowmobile trailer).
Thanks for any ideas.
Cost depends on what kit you get or build you own. $600 and up for a commerical kit? Pro/Cons? You'll have to search, I don't have one so I won't speculate.
Registered
i would get a tst with that setup. that way you can run the smarty timing and just have a fueling only box. will be the cheapest way. JMO.
That way you dont have to refill it like the w/m, you can turn it down or off to tow, and the on kill for just toying around.
The Water Meth would be a great option but as black diesel said the cons are refilling and getting it adjusted to your driving style! Also its (IMO) its not somthing you cut on and leave on! You have to make sure its cut off a few minutes before killing the truck to try the intake and such out! For seat of the pants i wouldnt say this is the best mod, but to stay on a stock turbo its the way to go!
44's n 454
24
03-08-2008 11:00 PM
chuckd25004x4
05-09-2005 06:12 PM
