More Power Please
Old 08-05-2005 | 10:09 PM
Jaa's Avatar
Jaa
More Power Please
Advise for more pulling power without damaging the drive train.
2002 CTD 3500 4.10 HO six speed. Has a dump body and weighs 9000lbs empty.
Could use some more umph up hills pulling equiptment and materials.
Thanks
Old 08-05-2005 | 10:50 PM
Jetpilot's Avatar
Mach 1.6 injectors and an EZ would be my recommendation.
Doug
Old 08-05-2005 | 11:50 PM
MadDog01's Avatar
The first thnig you want to do is get a set of gauges, pyro, fuel pressure and boost. You need to watch your EGT's when towing, so if nothing else you need a pyro. Then you might want a four in" exhaust and you'll probably want more air for those 1.6's and EZ. I personally wouldn't do any towing without guages.
Gary
Old 08-06-2005 | 02:57 AM
cumminsdriver635's Avatar
Id say for the most reliability, without worying about the clutch,and EGT's to much I would go for an Edge EZ. Gauges are also the first thing that should be done. At least a pyrometer, and you also need a fuel pressure on your 24 valve. Boost is not necessary but its fun to watch the needle swing
Eric
TDRattler
07-12-2008 08:42 PM
dieselJon
07-22-2007 01:39 AM
robox
10-18-2005 08:38 PM
j
12-21-2003 11:26 AM
