More power with a direct replacement turbo?
Does anyone make a direct replacement turbo that will give me fast spool, lower EGT's and a little (or lot) more power?
Look at my mods below... thats pretty much all I want to do...
Maybe a GSK or injectors...
Simple stuff...
Will the turbo make any difference?
Simple stuff...
No, the HX-35 you have will spool as fast as anything else you could get, and you would need more fuel than just a set of injectors and GSK would give you to see major gains from a turbo. And I would reccomend a plate before injectors. Maybe even DVs (that is my plan at least) Are your EGTs a problem? A timing bump to 16-16.5* would drop EGTs, and give you a nice power increase...
HP/TQ?
Does the truck run reliable?
I am guessing I am pushing close to 300/700... I have the plate about centered in the pump, trying to not kill my clutch. Yet.
And the truck is completely reliable. Plenty of power, no problems. Way better than stock.
Simple stuff...
Simple stuff...
loosen the afc spring, should give ya better spool up... or move the afc forward, and the plate.... your missing something! .... fuel!!!
after you have fuel... you'll need air!!!
Common
05-03-2007 07:40 AM
Common
14
03-15-2007 06:25 PM
Hunter11
07-26-2005 12:36 PM
