More Fuel pressure questions
why not just buy a fuel pressure guage designed for temporaryly hooking up. If you buy a cheap guage with a shreader fitting from any parts store they all sell them, it will just screw onto your banjo fitting if your fitting has the male threads on the end(probably covered by a plastic dust cap). just hook up the guage and strap it to your wiper and go for a drive, check its readings against your juices.
My fitting had an insert in the plastic tubing, but it was soft brass, so maybe it wasn't strong enough?
Anyway, my present setup works well and I won't have to worry about this for awhile, or so I hope.
jh
hey guys I recently hooked up an Autometer sending unit that is designed to use in the cab it is an oil pressure guage, (because the fuel is oil) it seems to be fine, but what do you guys think? it idle it sits at 15 psi and at WOT it is about 10.5-11 psi, I have a brand new Lift pump, do these reading sound right?
dodgeguy71
17
01-19-2012 12:52 AM
92smokin blacky
03-19-2010 11:39 AM
Skidoo01
01-29-2010 10:22 PM
