more black smoke!!
Registered
more black smoke!!
ok i just put my stacks on this afternoon! With my comp on 5x5 i can blow quite a bit of black smoke. However, i would like more but im not looking into spending a lot of money on fuel upgrades. Whats the cheapest way to get more smoke? Thanks a lot everybody
unplug the map sensor connector, the one from the Y in the comp harness going into the map itsself, don't know if it's good for the motor, but I know it'll throw lots of smoke down low!
Someone wrote on here about a selonoid blow off switch to dump boost. Having a switch so that you could pour it out, but it sure is a waste of fuel and it gives us diesel geeks a bad name.
Originally posted by blackdiesel02
already got 130 horse injectors
Still the stock clutch with the injectors & Comp on 5x5 ?....I'm not sure how long that will last
Registered
not sure on the name brand but i bought the stage 4 nozzles off of ebay. Yeah my clutch was slippin about 3 or 4 days after i rolled it out of the shop with the freshly installed comp
Second vote for the Mad ECM. I have one with a comp and stock injectors and it will leave a coal black cloud in every gear! The perfect anti tailgating device, just turn the comp on an floor it. Not only will you not be able to see them through the cloud, you will be putting plenty of ground on them too.
ADAM
ADAM
could it be the nozzles you bought weren't what you thought?? If you slipped your clutch with just the comp, how has it managed to last with "130 hp" injectors on top of that??
