Moly Lube Substitute?
Hey everyone I am going to do a retorque later today, When I installed my studs I used 70w gear oil on the washers, studs, and nuts for lube because I have no ARP Moly Lube. Is that ok or do I need a different subsitute? What would everyone suggest? Thanks!
All the bolt torque specifications for engine bolts are based on using engine oil. extra-slick lubes will cause you to overtorque. and overtorqueing is no better than undertorqueing.
mknittle
03-11-2015 10:47 AM
fire-fool
03-17-2011 07:04 PM
