Moe Power
Moe Power
OK Folks,
I have only posted a couple of times, however I have been reading the forums for over a year. I am fairly new to diesels. I know this has all been gone over before, but the more I read the more conflused I seem to get.
I have an 01 2500 stock truck with 135,000 miles (all highway very little towing)
I also have set aside about $5000.00 to play with for mods.
With the experience that you folks have, What mods would you reccomend that would fall within the dollar figure above.
I have to buy a Tranny and a Turbo within this money also.
I am looking for a combination of better performance and better fuel mileage. I will be purchasing a slide in camper after the mods are complete as well as a 40 foot trailer to drag around.
Any help would be greatly appreciated.
Re:Moe Power
I'm assuming you have a auto since you say you need a tranny. Between the tranny and turbo you wont have much to work with so a Edge Comp box and guages would probably be the best bang for the buck in your situation. The turbo will let you use more of the available power of the comp. Another wise choice is a fuel system upgrade if you happen to have a few bills left.
Re:Moe Power
I may have an additional 2000.00 to throw in there, depending on the performance gained or not gained from the Tranny and Turbo.
I am thinking about the ATS Tranny, but what turbo would be reccomended.
Thanks
Thanks
Re:Moe Power
Scott
Guest
Posts: n/a
Re:Moe Power
I would go 4" exhaust, gauges, 275 injectors (because you'll be towing), Power Edge Comp (for adjustabilty), DTT TC, valve body, and clutches. That with labor should eat eat all of your $5000 dollars. Throw in the extra for the turbo and youll have a 400+hp rubber burnin' monster towing CTD. That will will get 18-21 mpg hwy.
Have freind of mine with the same set up and its great.
Re:Moe Power
Thanks for all of the input. I was thinking along the same lines as the great suggestions. Only thing I was thinking different is possible DD3 injectors. Are there any disadvantages to running DD3's over the 275's ??
Also, does anyone know of a good shop within 150 miles of Delaware??
Re:Moe Power
[quote author=torqueman link=board=7;threadid=20329;start=0#msg194571 date=1065656265]
What do ya mean turbo desn't add more hp.Go from hx35 to hx40 & gain 40 hp.
[/quote]
Only if you have the fuel to support it.
Just changing the turbo won't do anything, on a stock truck.
After adding fuel, either with a box or injectors, changing the turbo will allow you to fully use the extra fuel you've added.
Fuel burns which spins turbo which pushes air which allows fuel to burn which spins turbo which sucks air, etc etc.
No fuel = no turbo spin = no air = no power.
phox
[/quote]
phox
Re:Moe Power
[quote author=torqueman link=board=7;threadid=20329;start=0#msg194660 date=1065664610]
I'm running dd2's&ufmcomp. & was told by dd I would gain as much as 40 hp just by adding a bigger turbo....
[/quote]
You have the extra fuel to benefit from it.
phox
[/quote]
phox
Plan_B
03-03-2012 07:29 PM
Treker
05-10-2008 07:58 AM
