Mods and Tuning for Best Fuel Economy ??
Old 02-07-2006 | 08:58 PM
Katmandu's Avatar
Question Mods and Tuning for Best Fuel Economy ??
How does one TUNE a 12V for the BEST fuel economy ??
Old 02-07-2006 | 10:29 PM
Katmandu's Avatar
Cool
Surely someone knows how to tune for economy on a 12V....
Old 02-07-2006 | 11:30 PM
BigBlue's Avatar
Timing, intake, exhaust. That's all I know. I'd say set the timing around 16-17*, get a scotty 2 intake, and a 4" exhaust.
Old 02-08-2006 | 07:32 AM
SHARPMACHINE's Avatar
From looking at your signature, timming is the onlt real improvement that you will see. Some 215 injectors with thin washers help some people as well.
Old 02-08-2006 | 09:29 AM
Katmandu's Avatar
Question
[QUOTE=BigBlue] I'd say set the timing around 16-17*, QUOTE]Roger that.
Does advance the engine timing have the same effect as bumping the ignition timing on a Gasser (by moving the torque up the power band. ) ??
Old 02-08-2006 | 12:01 PM
rattlerbob5.9's Avatar
timing
Yes katmandu that would be correct on a 12v you will sacrifice a little low end torque with advanced timing but you will like the overall performance better and it will help on mileage.
Old 02-08-2006 | 02:51 PM
tmacie's Avatar
[QUOTE=Katmandu]
With all the torque these motors put out you will hardly notice the low end loss. I could tell when I did mine, but just barely.
Travis
Old 02-08-2006 | 05:09 PM
Katmandu's Avatar
Question
How far is TOO FAR for a truck with the mods my truck has (See Sig) ??
Old 02-08-2006 | 05:38 PM
signature600's Avatar
16.5-17* is probably best for most people with 215 pumps!
I'll probably be setting mine around that if I ever get the thing on the truck
Chris
Old 02-08-2006 | 05:51 PM
DZLPWR's Avatar
You may want a better intake such as BHAF, or afe filter set-up. Timing will help. Higher tire pressure (dont wear out the middle of your tires though), tail gate UP, speeds around 55-60mph yeild good mpg, dont use engine to slow down-coast, tune afc for minimal smoke, stay out of the fuel pedal! Powerservice in the white bottle helps as well. No long warm-ups or idle times. If you want to go as extreme as full synthetics, they are claimed to help.
Old 02-08-2006 | 07:42 PM
AAmeeting's Avatar
I just went through a thread that said the BHAF will lower power. I will try to find it........
Old 02-08-2006 | 07:47 PM
AAmeeting's Avatar
Here it is https://www.dieseltruckresource.com/...ad.php?t=91016 read the whole thing.
Old 02-13-2006 | 05:38 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
scotty II helped my mileage, also the #10 palte on a 215 pump without gov springs and slid about 2/3's forward with gov arm adjusted and afc tightened down so that she jsut barely puffed. 16* timing and 285/75 16 tires with 3.54s yeilded 18-20 on long trips including fuel stops the average speed over 14 hours of drigning was 64mph 4"pipe with muffler which means i was running 70+mph regularly.. through nevada up and over the passes
I now have no scotty just an AFE, Lenny stage 4 injectors, twins, 16* timing the #10 plate slid back to about 1/2 maybe a hair under, afc tightened up, can push 50 psi no problem at WOT, a drilled Wastegate on the top turbo same tires and gears. 4" pipe with muffler average 17-19 get 17.4 mpg at 70-75mph get 19.2mpg at 65mph and i know i could do better if i wasnt so temped to romp on it occassionally.
No timing so stock 14.5*, the 215 pump with a #10 in stock location, afc tightened and stock turbo with a K&N filter int he box and straight exhaust
18mpg on the highway at 65mph 16mpg at 70-75 mph
my driving style hasnt changed 1 iota
All in a 98 12v 215hp 6spd equipt QC SB 4x4 with 160k miles You decide
SN162
06-05-2007 10:20 PM
cromulius
14
06-11-2006 10:52 AM
PapaPerk
12-05-2004 11:14 PM
mr T
06-12-2004 12:54 AM
johnr9q
04-25-2004 01:18 AM
