Mo Power
Mo Power
Hey Guys,
I was thinking of getting some injectors and was wondering what you guys would recommend? I'm not looking for hugh power just a little better then stock something in the 50 - 60 hp range. As always fuel mileage is important
Thanks,
Topper
Thanks,
Topper
Might consider rv 275's or maybe mach 1's. Your tranny should hold the 275's no problem, but it might be borderline w/ mach 1's. Both of these mild injectors should increase fuel milage and the extra controlable smoke is always a plus.
Hey thanks for the reply! Where should I order the rv275's from? What HP gain should I see? I assume that they'll work well with the EZ box that I have and the 4" exhaust.
Thanks for the help!
Topper
Topper
You can pick up a set on Ebay for around $280. They may be listed as Bosch 300hp injectors but they are the same as RV275's.
You may be pushing the limit though, running the edge box and the injectors with a stock tranny. The 275's should give almost the same kick that the Edge EZ gave you truck, at least that's what they did for mine (back when I was running em)
Hey guys I called Cummins North East in Albany to order injectors but they wouldn't sell me any RV 275'S for my truck. Well plan B where should I order them from???
Thanks,
Topper
Thanks,
Topper
powerwagon440
01-20-2003 08:50 PM
pwabbott
14
12-20-2002 08:23 PM
