metric size for fittings in fuel lines
Can anyone tell me what the metric size on the fuel fittings in the lift pump, fuel filter assy, and schrader valve on the VP44 are? (2nd generation) I think they're 12mm x 1.5 or 12mm x 1.25. I want to replace those fuel lines/banjo bolts with -6AN fittings and lines. Thanks.
Re:metric size for fittings in fuel lines
They're 12mmx1.50 is what your looking for. earl's # is 991944
you can also get them for -8 if needed. hope this helps.
Scott
Scott
ppsi
01-30-2012 07:16 PM
kawi600
05-04-2006 09:43 AM
36
06-04-2003 02:30 AM
