Melted Piston Pics from the tow rig
#31
I'd rather have this sort of thing happen now than half way through the pulling season.. At 296k it wasn't exactly "due" for a rebuild but it definitely can't hurt.. We'll see how the bearings look.
#32
Dang Garrett that thing broke bad, good thing the pulling season is over... I'm sorry bud, other than doing the balancing and everything you could add a ZZ intake manifold and just add on to the porting and polishing. On a side note how does that 64/14 do towing? Do you have bigger tires on the truck than factory?
#34
#35
The truck has 4.10s and 265 tires, it tows is awesome but the RPM's are at 2500RPM at cruising speed so its definitely in the powerband.
#37
NP, IIRC its the line that connects down by the oil filter, NOT the line that connects to the head. I T'd in right by #5/#6 on the hose right where it turns to rubber coming out of the firewall.
#43
Thanks for bringing that cooling kit back to my attention...I need to order one ASAP, while the head is off! Although I'll alter th plumbing a bit I have a water cooled Garrett charger, and I'm moving the heat exchanger, so I'll just eliminate the lines coming off the head all together.
Chris
Chris
#44
The Guru
I lost that number, I haven't orderend mine yet, but with me redesigning my twins and replacing my head, I might put in that coolant kit. I have a history of running my truck into overheating area once or twice myself. Take some after pics of the ride bud. Maybe you could talk Piers into building a motor for ya. I would try the 3rd gen pistons as they have the mods for extra oil swirting/coolant thingy. They fit in the holes and are not too exotic of a piston. You sleeving the motor? What color you painting the new motor? I like hemi orange or cummin's red would be a hot color.
#45
I'm not changing to a 24 Valve head so I think 3rd gen pistons aren't an option.
I have a good engine/machine shop that I work with, but thanks for the suggestion re Piers, I do a lot of business with his new business
As long as the cylinder wall can be cleaned up I don't plan on sleeving it.
I will take some after pics for sure, thanks
