Mechanical fuel pressure gauge
Nope and I highly recommend that you don't get one. Give Rod at Wildcat Diesel or Merrick at Laredo Performance Diesel a call and they can hook you up with everything you need and nothing you don't.
I have been running an Isspro mechanical without an isolator for several years with no problems. However, I Do carry tools to fix any leaks that may occur. You could probably just install a needle valve under the hood to shut off the fuel supply to the gauge if there were a problem.
Location: Springtown Texas, the land of MILFs and Honeys
I run ISSPRO with a needle valve. No isolator. If it springs a leak, I can turn the needle valve shut till I can get it fixed.
It's not going to leak though. ISSPRO is good stuff and I used a bulletproof line and fittings to do the connections with.
It was discovered with the Isspro gauge that if you run direct to it with your fuel line it will get a rattle to it. The simplest way to fix this is to install a small ball valve inline to cut the flow down to the gauge. Just keep opening the valve until you reach your normal FP at idle.
http://www.grainger.com/Grainger/pro...835780&ccitem=
This one is actually better Dr.
It's 1/8", the size most often used for automotive gauges and lines, no reducers needed. http://www.grainger.com/Grainger/pro...835462&ccitem=
Shovelhead,
Is that 1/4 S.S.? Do you happen to remember the length? Ive been looking for some reasonably priced S.S. braid but cant find any....Ill probably have to call Rod.
Thanks.
PS, Bill I just closed my eyes and picked a needle valve from the Grainger page
Thanks.
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
the only problem with not having a isolator and rigging up a needle valve ball valve if you spring a leak in your cab while bombing down the freeway at 70 mph how long is it gonna take to shut down your engine safely diesel leaking from behind an a-pillar or all over your carpet makes a pretty undesirable mess not to mention the smell
