MBRP 409 Stainless Steel Exhaust Rust????
I've have had the Cool Duals on since March 06' and they look terrible!!! For $900.00 you would think this stuff would not rust!!! There are spots of rust everywhere and people like to "point" that out!! Is there a MBRP Honcho on the DTR?? If you are out there, what is the return policy/customer service support for this product? I love the sound and looks of the duals but I'm not impressed that my buddies have aluminumized Flo Pro duals and they look better than my "409 stainless steel" system and his system is 6 months older?
409 stainless is not as rust-resistant as 304 stainless.
On edit - see the following:
Rusty
300 Series—austenitic chromium-nickel alloys
Type 301—highly ductile, for formed products. Also hardens rapidly during mechanical working. Good weldability. Better wear resistance and fatigue strength than 304.
Type 302—same corrosion resistance as 304, with slightly higher strength due to additional carbon.
Type 303—easier machining version of 304 via addition of sulfur and phosphorus. Also referred to as "A1" in accordance with International Organization for Standardization ISO 3506[6].
Type 304—the most common grade; the classic 18/8 stainless steel. Also referred to as "A2" in accordance with International Organization for Standardization ISO 3506[7].
Type 309— better temperature resistance than 304
Type 316—the second most common grade (after 304); for food and surgical stainless steel uses; Alloy addition of molybdenum prevents specific forms of corrosion. Also known as "marine grade" stainless steel due to its increased resistance to chloride corrosion compared to type 304. SS316 is often used for building nuclear reprocessing plants. Most watches that are made of stainless steel are made of this grade. Rolex is an exception in that they use Type 904L. 18/10 stainless often corresponds to this grade.[1] Also referred to as "A4" in accordance with International Organization for Standardization ISO 3506[8].
Type 321— similar to 304 but lower risk of weld decay due to addition of titanium
400 Series—ferritic and martensitic chromium alloys
Type 408—heat-resistant; poor corrosion resistance; 11% chromium, 8% nickel.
Type 409—cheapest type; used for automobile exhausts; ferritic (iron/chromium only).
Type 410—martensitic (high-strength iron/chromium). Wear resistant, but less corrosion resistant.
Type 416— easy to machine due to additional sulfur
Type 420—"Cutlery Grade" martensitic; similar to the Brearley's original "rustless steel". Also known as "surgical steel". Excellent polishability.
Type 430—decorative, e.g., for automotive trim; ferritic. Good formability, but with reduced temperature and corrosion resistance.
Type 440—a higher grade of cutlery steel, with more carbon in it, which allows for much better edge retention when the steel is heat treated properly. It can be hardened to Rockwell 58 hardness, making it one of the hardest stainless steels. Also known as "razor blade steel". Available in three grades 440A, 440B, 440C (more common) and 440F (free machineable).
Thats odd...I had t409 and it held up great... is the rust you talk about just minor surface stuff? Can it be scuffed off without much effort? Contact MBRP with some pictures and see what they say...
Good luck.
Good luck.
I work at a medical instrument machine shop and there are NO totally stainless metals. Yes even stainless will rust and discolor. If you can get ahold of some nitric acid you could coat it with that and let it set about 20 minutes then hose it off in the driveway. This would give you some resistance to rusting for a while but it does seem odd that your shine didn't last longer.I would contact mbpr
basicly 300 series stainless has no iron in it and wont rust. Now it can oxdoize and get that white stuff on it and it does bad with salt and will discolor in heat. but it wont rust. 400 series has iron in it and therefore will rust. The other truck has a mbpr and started rusting almost instantly but I knew it would rust and it was cheap so thats why we got it. Without going to the expense of a 300 series exhaust the alluminzed on mine seems to be holding up great
Wicked500R
02-16-2009 07:08 AM
kully560
08-21-2006 03:17 PM
floridagc
03-21-2006 12:01 PM
