Max boost with stock turbo?
Old 04-28-2003 | 12:56 PM
ET_178z's Avatar
Re:Max boost with stock turbo?
That is what I figured but I just wanted to be sure... Thanks. Also, what kind of boost have you seen with a hx-35 on a 24 valve.
Old 04-28-2003 | 08:48 PM
59Dsul's Avatar
<br>Mine will hit 45-46 for a couple of seconds, then hangs around 42-43 at WOT if I stay in the throttle.
Old 04-29-2003 | 06:58 AM
yrusoslow2's Avatar
The boost elbow with the adjustment screw that I have came with the tst plate that I ordered. When I had my hx35 I was able to get 44psi with that but like everyone else said after about 35 or so it just starts to make hot boost. My egt's never went through the roof but they definatley got up there. A buddy of mine has a 2001 with the edge comp box and his came with an elbow as well but it did not have the adjustment screw in it. He ordered just the elbow from tst and now he is pushing about 40 psi of boost with his hx 35. His egt's do however go throught the roof. He can hit 1500 degrees no problem.
Hetdiesel
08-06-2009 09:18 PM
Jordan5687
03-28-2007 02:32 AM
chrigu
11-26-2006 02:54 AM
cumminsdriver635
08-08-2005 06:46 PM
belfert
09-09-2004 04:23 PM
