Max Boost with stock head bolts
Old 09-23-2007 | 10:28 PM
jeepin's Avatar
I just bought my first dodge cummins it is and 02 HO 6spd.
I am thinking about maybe doing a bigger single turbo and would like to know how much boost the stock head bolts can take?
I have had about 15 cars including a cobra mustang a chrysler crossfire and some older muscle cars and have to say that this is the funnest vehicle to drive that I have owned I should have bought one along time ago.
Only thing I dont like is that I cant stop buying stuff for it this addiction is worse than with my jeeps.
Old 09-23-2007 | 11:14 PM
Ph4tty's Avatar
Some guys have run twins for over a year with stock headbolts, 60+ psi,.... other blow HG's in stock form.
Most will say around 40. Wait for the t-stat to open before flogging it
Old 09-24-2007 | 08:54 AM
jeepin's Avatar
Ph4tty thanks around 40 is what I was thinking about so I will have to think about doing studs if I go any higher.
Can you just do studs or do you have to do an aftermarket head gasket or other head work at the same time?
Old 09-24-2007 | 09:48 AM
Ph4tty's Avatar
I just studded mine without removing the head. I'm hoping for the best =P
Old 09-24-2007 | 09:57 AM
jeepin's Avatar
Ph4tty so you can just do one at a time?
Old 09-24-2007 | 10:09 AM
Ph4tty's Avatar
Mine were done by TRE diesel, but yes one at a time starting in the center and spiraling out.
Old 09-24-2007 | 11:54 PM
jeepin's Avatar
Thanks for your help
Krob
18
03-14-2008 08:01 PM
Conn
12-29-2006 06:30 AM
streetsmoker
15
12-18-2006 04:03 PM
belfert
09-09-2004 03:23 PM
Gypsyman
07-28-2004 12:11 PM
Quick Reply: Max Boost with stock head bolts
