Max boost with just a plate?
Old 05-19-2007 | 12:23 AM
Common's Avatar
I hit 35-38 psi VERY fast.
Will my headgasket be OK?
Old 05-19-2007 | 12:24 AM
displacedtexan's Avatar
Mine has been for 45k. With the timing at 16.5*
Old 05-19-2007 | 12:25 AM
Glad to see you put the plate in
Like it?
Old 05-19-2007 | 12:27 AM
Common's Avatar
Like it?
Its un-believe-able...
I couldn't put my tools away fast enough...
As soon as I got on it.... man...
I was speechless...
Its like having a never ending bottle of NOS....
Old 05-19-2007 | 12:30 AM
Common's Avatar
Like it?
Think I could use an intake?
Sure is a nice change... Where did you put it in the pump?
Old 05-19-2007 | 12:32 AM
Common's Avatar
Exact as the stock plate...
Had to adjust the starwheel quite a few times...
Think I have it perfect now...
Need an exhaust tip since my fender is BLACK!
Old 05-19-2007 | 12:39 AM
I am still running the stock intake, I want one, but don't really need the EGT drop. The stock box will flow enough for up to about 300 hp.
Old 05-19-2007 | 12:53 AM
Common's Avatar
What do your EGT's read under full acceleration in 4th?
How much of a difference did the GSK make on your 215?
Stock clutch?
Old 05-19-2007 | 12:57 AM
Teddy Bear's Avatar
Congrats on installing the plate So the plate is in the stock position? Why not slide it full forward and take it for a test drive just to see how u like it?
Old 05-19-2007 | 01:03 AM
Common's Avatar
I don't know how to adjust the gov. arm...
And I hear of people breaking things when they start going nuts...
Reminds me of this picture I saw of a guy holding up a twisted driveshaft
Old 05-19-2007 | 01:08 AM
I don't have EGT issues, I have never seen over 1350* but I also don't floor it. I can slip my stock clutch pretty much at will, and don't have the money to replace it now, so I drive easy in 4th
The GSK is nice, full fuel to 3400 RPM
Old 05-19-2007 | 01:09 AM
Common's Avatar
Timing make a big bit of difference?
Ever break anything?
Old 05-19-2007 | 01:17 AM
I did it all at once. And no carnage yet. Other than a dying clutch.
Old 05-19-2007 | 01:21 AM
Common's Avatar
Makes me want to go out now!
I like this power, and since this truck is my wife and daughters bread and butter I think I'm gonna stop for a while...
Can't have downtime...
Does the plate put a hurting on the drivetrain, shorten the life of the engine?
Sorry for all of the questions, but y'all saw how long it took me to put the plate in
