Max Boost
Max Boost
Whats the max boost numbers you are all seeing w/ a similar set up to mine? Comp box, straight pipe and afe. Thanks guys!
Good question.....I'm not sure.....Since yours is an auto, it is rated at 215 hp stock, where as the 5 spd is 235hp......maybe that is the difference? Can you verify that your wastegate is 100% closed? You are using the supplied boost elbow, right? Since both the 215 hp and 235 hp engines make their peak hp at exactly the same boost and are both gated to 20 psi, I would think the Comp should give similar boost increases between the two. IMO, 28 psi is a bit low.....that is absolute peak boost? Do you know anyone with another Comp you could plug in? Also, check to make sure the pump wire tap has a good connection......if it were stuck in EZ mode, 28 psi would be about right.
Originally posted by MLR1
I could only hit 29 until I installed DD II's. Then I could get up to 34. I would bet that your elevation is killing you.
Yup...Evelation!
I can hit 51 psi at 650'.....In Colorado Springs...on a 75* day I could only pull 40 psi boost.
Also, if your tranny is stock....it's surely slipping at 5x5 on the comp at heavy throttle.
RJ
RJ
Thanks MLR1, but I know what the ez mode is.
The wire is tapped, but CTD NUT you said it might not be completely tapped or stuck in ez mode? How would I check that?
To check the tap and make sure you are making a good connection. Make sure the Comp is off, turn the ignition on (but do not start), then use a volt meeter to verify you have 12 volts on the Grey wire. As for being stuck in EZ mode, I don't have a clue on that one .
Max
Max
When the key is in the on position the pump wire will show 12 volts. If you have a good tap on the pump wire the same 12 volts will show on the Grey wire that is connected to it. The voltage comes from the truck not the chip. Once you start the engine then the voltage readings will be all over the place depending on RPM, fuel requirements, ECM programing etc. Then when the chip is turned on it will start manipulating the voltage as well. I hope that makes some sense.
Max
Max
Dually Driver
13
11-13-2007 09:10 PM
GTSDave
07-08-2005 09:06 AM
belfert
09-09-2004 03:23 PM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
