Massive Defueling ...... HELP!!!
Old 08-18-2004 | 12:25 PM
  #31
SilverDodge's Avatar
ip? Whats that? im going to hook it up to the ODBIII tomorrow
Old 08-18-2004 | 12:29 PM
  #32
OPIE's Avatar
Injection Pump, sorry I should of written VP.
Old 08-18-2004 | 12:31 PM
  #33
ahhh i see. Well, hopefully it wont come down to that.... but i appriciate the offer.
Old 08-18-2004 | 12:33 PM
  #34
sorry - missed the last part of the post. Both trucks have have 3.55's in them
Old 08-18-2004 | 01:00 PM
  #35
MCummings's Avatar
Sounds like a classic de-fuel for '01 Auto's....
Maybe that's why the previous owner wanted a 6-speed instead of his Auto?
Check into the "Redline" Fueling box from Blue Chip, Marco's Mad ECM, and the BD R.A.D.
'01's will defuel over 10 PSI boost (and low, or 0 MPH), in 1st gear, 1-2 shift, going into lockup, and I think the 3-4 shift.
Your trucks sounds like it has a more pronounced de-fuel than most others. Could be alot of things. I would guess your race pump would be a big amplifier of the de-fueling.
Don't go P-pump just yet.......
Merrick
Old 08-18-2004 | 06:00 PM
  #36
merrick - i have both a mad ecm and a rad in the works right now. The rad will be a temp fix hopefully and the ecm will be the permanet fix if all goes well. I am not going to put on a p-pump.... just a pipe dream
- Darin
Old 08-19-2004 | 09:41 AM
  #37
OPIE's Avatar
- Darin
SD, so have you spent any money on your truck lately?
Old 08-19-2004 | 01:18 PM
  #38
im so broke i cant even pay attention!!
Old 08-19-2004 | 01:28 PM
  #39
P1698 No CCD Messages Received From PCM
P0217 Decreased Engine Performance Due To Engine Overheating Condition
P0237 MAP Sensor Voltage Too Low
P0234 Turbo Boost Limit Exceeded
P0501 ????
Those are all of my codes. I cleared them all. The 1698 makes sense because i was cutting wire to stop the defuel. Overheat? it hasnt overheated ever.....hmm. Map too low? Overboost is easy - had the comp off the truck for a day
Old 08-19-2004 | 02:06 PM
  #40
CDRAM's Avatar
The 501 code is for the speed sensor or vss rational, thats the code set by cutting the white wire w/ orange trace. The 217 tells me that the ecm is thinking that your eng temp is too warm. Coolant temp sensor? Second question are the sensors for the coolant temp and vss( vehicle speed sensor the same on auto's and stick trucks.
Old 08-19-2004 | 02:08 PM
  #41
CDRAM's Avatar
Were any of these active codes, and how many times were they set? The scanner will tell you that.
Old 08-19-2004 | 02:24 PM
  #42
i dont know if the codes were active or not.... the guy was tellimg me by the look on his face that he had better things to do then waste time helping me. Oh well. The coolant temp - didnt have it hooked up all the way so thats fixed
Old 08-20-2004 | 02:32 AM
  #43
put the RAD on tonight. It took care of all of the defueling. I still need to fix it, i dont like having to flip a switch, lose my tach and have the check engine light come on every time i want to mess around. Hopefully the MAD ecm will help!
Thanks Opie, Merrick, Eric, and Don for all of your help!!!
- Darin
Old 08-20-2004 | 08:18 AM
  #44
BigBlue's Avatar
So how's it pull now?
Old 08-20-2004 | 11:42 AM
  #45
oh boy.... its real fun to drive now. My tires arnt very happy however The next week holds bigger injectors and a MAD ecm. I cant wait!!
