Marvel Mystery oil
Re:Marvel Mystery oil
If you really feel the need to use an additive you should give Lucas a try. I use a quart of their oil additive when I change my oil and its still brown, not black, after 6,000 miles ;D. Not trying to start a brand war, its just a suggestion .<br> Wheels
It is not supposed to have lubricating properties. It is a detergent! Your engine oil takes care of the lubricating. Mystery oil just helps keep your engine cleaner. Helps reduce detonation in gas engines by raising the octain. Shoot, and the stuff smells great.
If it boosts octane it does nothing for a diesel then. As for aircraft they will void all engine warranties if traces of the mystery oil is found! As far as Im concerned aircraft engines work darn near the hardest and if its no good for them then its no good my my CTD either.
My family has been using MMO for over 50 years. But only in gas engines. I use it in my bikes, ATVs, lawn mowers, automobiles but never in a diesel. It's more of a detergent than a lubricant. For a diesel you would want both. Stanadyne Performance Formula would be a better choice for me.<br><br>MikeyB
[ I use a quart of their oil additive when I change my oil and its still brown, not black, after 6,000 miles ;D. Not trying to start a brand war, its just a suggestion .<br> Wheels<br>
Original Junior
04-27-2005 10:30 PM
Hummin Cummins
07-05-2003 10:55 AM
