Marine Headgasket
Marine Headgasket
Ok guys this is for all of you with a 24v that have replaced you OEM headgasket with a 20 thousandths over marine gasket.
How do you like it?
Does it smoke upon startup?
Any trouble starting?
Loss/gain of noticeable power?
Also please post if you had the head milled and if so how much. Also please post if you have an ETC or an ETH. I have 3 trucks that we are O-ringing and I am considering using this gasket. All of the trucks are between 500-600 HP single charger with boost levels below 60 psi.
Thanks for your input.
Doug
How do you like it?
Doug
Shoot one of the trucks made over 590 uncorrected HP @ 37 lbs boost. This truck is a daily driver that pulls horse trailers all the time. Its nice seeing trucks come together and work well with the right complement of parts.
Doug
Doug
Re: Marine Headgasket
How do you like it?
Doug
How do you like it?
Doug
The gasket that blew was checked for oring depth and sealing quality. It was perfectly sealed on the stock firerings. Two bolts were stretched to .020".
brandon.
