map unplugging.
map unplugging.
why do people notice power gains when the map sensor is unplugged? I notice that i can puff some smoke when i want to and it seems to have more low end. It also runs really rough, why is that. My next step is some injectors but it will take some saving gotta slow down on the scotch for a while. but i can do it!
Since there is no manifold pressure signal going to the ecm, the truck gives more fuel. Most of the gain is in the way the truck responds at low rpm. Somebody dynoed with it unplugged and gained, I think, about 10hp. The only box that I know it works good with is the comp, other seem to run like crap with it unplugged. When I still had my Van Aaken box, I unplugged the MAP sensor and it gave a good boost in low end response, but I had a check engine light.
thanks that makes sense now. i noticed that you have the holley blue inline pump what kind of fittings did you have to get to make it work? can you get what you need at a advance auto or something similiar?
b.t.w. noticed 36 psi without map sensor 33-34 connected.
smokinstrokes99
11-08-2007 10:02 PM
01smoker
09-19-2007 10:35 PM
Big Deezul
17
12-19-2005 06:12 PM
BigBlue
58
11-17-2005 12:41 PM
