Map Sensor on Edge Juice/Attitude
Old 12-29-2006 | 05:04 PM
haloman's Avatar
Help me,
I have a friend with an 01 that just got a Edge Juice w/Attitude and it runs good but not enough smoke for him off idle. I know you can unplug the map sensor for smoke off idle on the comp boxes. So does it work with the Edge J/A? and where is the sensor to unplug? I work really well with pictures. Please help this guy is dying for some smoke.
TIA
Old 12-29-2006 | 06:16 PM
CTD01's Avatar
Smoke
This trick does not work with That setup. Does he have the IP wire tapped? I can fill the road with smoke if I wanted to. Also get the hot juice big difference between 5 and 6.
Old 12-29-2006 | 07:03 PM
TNfarmboy's Avatar
I am pretty shure you can. Do a search on MAP or Smoke and you should find plenty of stuff to look at. I remembered reading something a while back here it is. You said an 01...here is a picture from Mopar1973Mans site for an O2 but they are all in the same place just behind the fuel canister.
Old 12-29-2006 | 08:55 PM
REF>Lancer's Avatar
The low boost settings...you can set it to disregard boost,It'll smoke plenty.
My pump aint tapped,and I can still get a fair charge of smoke,off idle.
Old 12-30-2006 | 12:24 AM
CTD01's Avatar
Map Sensor
I tried the map sensor thing with mine ,no more smoke.
Old 12-30-2006 | 12:53 AM
TNfarmboy's Avatar
Sorry, just going by what I have read....have a comp myself.
06CTDforAU
01-28-2008 12:25 AM
Jordan5687
03-12-2007 12:00 AM
GCF724
03-02-2007 12:18 PM
CTD01
01-03-2007 11:17 AM
razor6
22
01-20-2006 04:43 PM
