manifold and turbo gaskets
Old 06-06-2009 | 06:44 PM
Bradleysram's Avatar
i have a twin setup that im putting on my truck. What i was wondering is when you pull the manifold and turbo flange are the gaskets reuseable or should i plan on replacing them. Also the oil drain line. If you had to replace these where did yall get all the gaskets?
Old 06-06-2009 | 06:59 PM
meangreen96's Avatar
Depends on mileage, but I wouldn't reuse them. You don't want to have to pull everything back off if you have a leak.
The turbo/manifold gasket is a Dodge or Cummins part. Pretty sure the block manifold gaskets are too. I have a aftermarket manifold so that's why I can't remember on that one.
Old 06-06-2009 | 07:47 PM
Mike D's Avatar
Make sure you get the new style multi layer steel for the manifold/block gaskets.
Old 06-06-2009 | 09:48 PM
its got 120k miles. Thats pretty much what i figgured. I was wanting to find some better than stock ones and ive been looking at the MLS ones.
92smokin blacky
08-04-2009 11:39 PM
Micaiahfied
03-02-2009 05:20 PM
doggyjumper
05-24-2007 11:48 PM
90firstgen
04-05-2007 11:45 PM
Big Blue24
01-23-2007 02:56 PM
