Mad ECM What,where,how
Old 10-16-2005 | 12:14 PM
GSP's Avatar
GSP
What is a Mad ecm? Is it a plug in box like a edge?
Where do buy a mad ecm?
How much $$ is a Mad ecm?
Ive checked the advertised venders and dont see anyone that sell a mad ecm or a van akin
Also who sells a Van Akin?
Old 10-16-2005 | 12:18 PM
HOHN's Avatar
MAD ECM is a factory ECM (engine control module) that has had the factory software erased and replaced with a high-performance program. It is not a plug in module, it replaces the existing ECM. It is famous for incredible pedal response, and practically eliminates all turbo lag. It also eliminates the factory boost limit, torque limiters, and such like that.
You can get one from Bob Wagner at www.wagnerandassociates.biz It's also known as the Catcher (which is short for Clutch and Traction Challenger). Believe me, it will challenge both your clutch and your tires (if you have a stick).
The Van Aaken box is a box similar to the Edge EZ, made by a company called Van Aaken Developments. It advances timing to give you more tq and a bit more mpg. It also brings the factory fuel curve in slightly earlier to enhance bottom end torque. I'm presently running one, and it's a nice unit, but MUCH milder than the ECM is. The ECM is quite a bit more aggressive.
Old 10-16-2005 | 12:35 PM
GSP's Avatar
GSP
Thanks Hohn... Whats a Van AAkn? who sells it.?
Old 10-16-2005 | 03:08 PM
GSP's Avatar
GSP
Thanks again Hohn. My truck was originaly sold in Calif so it has the Calif computer and I cant use my lock-up switch without getting a engine check code.
Will the Mad ECM replace my hole Calif computer crap so I can use the lock up switch without getting coded?
Ill try and get ahold of Bob and ask him also
Old 10-16-2005 | 05:18 PM
HOHN's Avatar
The Van Aaken is a plug in "box" like an EZ. The cheapest place to find them is Ebay, but Mark Craig (a DTR advertiser, of Diesel Performance Parts ) sells them for like $385 BRAND NEW. Read more about them at www.van aaken.com
H
600 Megawatts
01-22-2005 05:53 PM
TurboPirate24v
10-28-2004 07:27 PM
FMF MX
45
10-19-2004 09:18 PM
TurboPirate24v
10-08-2004 01:46 PM
Battering Ram
18
02-19-2004 02:03 PM
Quick Reply: Mad ECM What,where,how
