Mach 5-6 Injectors with HO Pump?
Old 03-08-2005 | 10:42 PM
Mike Holmen's Avatar
The Guru
I already have a maxed out 24v head and almost race cam. The engine that I plan to build for next year will be an all out drag motor built for running drugs. The crank was just an idea that I was thinking about. I'm not sure what my next move is. PDR had a 24v engine in their shop that ran 10.20's on drugs. It still had the VP pump on it so it can be done. It would be fun just to build an engine to see how far you can push the power up on, 10.20's is pretty fast for a 7000lb truck.
Old 03-08-2005 | 10:46 PM
1ST GEN.'s Avatar
fuel pumps won't help horsepower, they only send fuel to the injector pump they don't meter or deliver fuel to the injectors
Old 07-12-2005 | 08:33 PM
JAFAW's Avatar
Hey don am new to this could you please explain the hotrod pump for me.
Was looking at rv275 what is the difference on the " mach2" ?
Thanks
Old 07-13-2005 | 01:02 AM
HOHN's Avatar
Don's Mach 2 is a 100hp increase. The RV275 is about a 40hp increase made by Bosch. Different leagues of injectors.
A hot rod VP44 is simply an effort to improve the fuel delivery of the VP44 by combining the best parts of the Standard Output and High Output pumps. The HO pumps have a little faster, more aggressive delivery-- the SO pumps have more volume. The hotrod is a hybrid of sorts, in an effort to make more HP.
Justin
RonA
14
09-04-2007 12:09 PM
sway825
12-08-2004 11:21 PM
fitzer
02-01-2004 12:20 AM
HOHN
36
01-22-2004 12:14 PM
BAD HABIT
10-26-2003 12:52 AM
Quick Reply: Mach 5-6 Injectors with HO Pump?
