Mach 4's.
Howdy, 1st. post but been reading and learning for over a year now.
You can see from my signature that I have Mach 4's, EZ and stock turbo. ETG's empty are not a problem (less than 1250F) until I am in 6th gear doing 95mph. I made the newbie mistake of putting in the RV275's first, then went straight to the Mach 4's. They seem to do the job
I did a Mustang dyno run (dyno set to 7500lb) and ran 353.5 HP and 825 TQ, both at 2250 RPM.
I have a question about your posted HP/TQ numbers. What dyno did you use for the testing? I here the Mustang dyno gives about 10% less, any opinions?
Chriss that sounds about right at that elevation with uncorrected #'s. Corrected you would be really close to 400.
I guess the next thing to do is shop for a hybrid turbo, but I still want to have fast spool up. Need to burn all the fuel those Mach 4's are put out
Originally Posted by Mike D
Why not a Phat Shaft 62 or HTB2?
Is there data to compare the differences between these various turbo options? Or do we have to rely on the experiences of others?
TURBO.........................60 MPH...................70 MPH..........................EGT's @ 30 PSI
HY-35.......................... 5 psi....................... 10 psi ........................ 1200*
HX-35.......................... 5 psi ....................... 9 psi ......................... 1200*
35/40 Hybrids ............... 4 psi ....................... 9 psi ......................... 1100*
HTT HTGB .................... 3 psi ....................... 7 psi ......................... 1100*
KSB1-2 ........................ 6 psi ....................... 8 psi ......................... 1075*
Piers HX-40 .................. 5 psi ....................... 7 psi ......................... 1050*
HTT HTB2, 12cm2...........4 psi ........................ 6 psi ......................... 1000*
KSB-1 ......................... 3 psi ........................ 6 psi ......................... 1000*
B1-2 ........................... 3 psi ........................ 5 psi ......................... 1000*
Holsett HX-40 ............... 0 psi ........................ 0 psi ......................... 1000*
HTT SP 66 .................... 0 psi ........................ 3 psi .......................... 950*
Full B-1 ........................ 0 psi ........................ 3 psi .......................... 900 *
If I remember right. This data is on different trucks running different setups. But, it still gives you a good idea since all tests were equal if you can factor out a bunch of other variables.
[QUOTE=Phatboy]Both. Call Doug @ http://www.performancedieselwarehouse.com/ and he'll steer you in the right direction. Here's some compartitive data compiled by Rjohnson on an older thread:
Thanks, do you like your Mach 4/Phat Shaft 64 combo?
Looks like me and Hohn are it.
I'll post my findings for those interested in getting some bigger sticks.
I have some 4.5 in the truck. At WOT I'm seeing about 38-39 lbs of boost (stock turbo HX35/12) and about 850-875 degrees post turbo temp, I'm going to move the pyro pre-turbo soon. Cruising down the hwy. I'm at 550 deg. at 65 mph. From my understanding post turbo temps messure roughly 300 deg less than pre. with little boost, I personally think it's about the same just cruising down the highway maybe only 100 degrees different, but as the boost comes up the difference in temps grows.
From a stand still with zero boost matted, smoke is a problem... After say 20 lbs of boost it pretty clear behind me.
I guess it will get interesting once I decide to add a fueling box.
I'll be keeping a close eye on the turbo threads.
When I first put in the M4s and a test unit Catcher, I saw 1500 for the first time! This was at 38psi on the stock charger. I suspect that the toasty EGTs were due to tight turbine side choking.
Lately, I've noticed that my PEAK EGTs were lower than when I first tested the ecm/m4 combo.
I suspect the reason that the EGTs are lower now is due to a clutch that won't load the engine fully-- it slips instead
Originally Posted by Eskimo
According to that, a piers HX-40 runs hotter than a stock HX-40..
weird... [shrug]
weird... [shrug]
