Mach 4's
Mach 4's
Does anybody know where I can buy a set of Mach 4's. Can't find anyone that stocks these Injectors. I have tried the dealers from the F1 web site, but no luck. Please Help. One other question, are the DDP4's just as good as the Mach 4's.
Injectors are a lot like it use to be with the TST PM3 vs the Edge Comp.... very hard to find anyone that has run both F-1's and DDP 150 hp (or other brands).
I can tell you that I have run F-1 100 hp's and other 100 hp injectors and there was no comparison. F-1's were cooler running, smoked less and made more HP!
Other brands can work OK and fit tighter budgets, so they have their place. But there is a noticable difference, IMO.
My Mach 4's are spectacular and I would not run any others..... Except maybe Mach 6's.
RJ
RJ
RJ
RJ
Then again, I have the stock HO pump, so there's not much point in going past 4s.
500HP should be doable with 4s and maybe some chemistry.
jh
I've personally settled on a 71 series HTT 62/14. I want to free up the hot side and still preserve some spool. The larger hotside is more efficient, will blend right in with future twins (if that happens) and is drug-friendly.
JUSTIN
RonA
14
09-04-2007 11:09 AM
sway825
12-08-2004 10:21 PM
smittybuilt
14
01-05-2004 01:42 PM
BAD HABIT
10-25-2003 11:52 PM
