Mach 1.6s ?
Mach 1.6s ?
is any one towing with 1.6s with a stock turbo? if so what EGTs do you see? and does it smoke? how do you like them?? trying to stay a head of the fords
thanks
thanks
That is a hotly debated question, if you have a fueling box and bigger than stock injectors, I would recommend FASS, as I did so as not to worry about stock setup anymore. Many others do Scotty smart fuel, and Vulcan kits,your preference, they say they are good to 350+hp.
Because MAD ECM stays within stock fueling parameters(timing is higher) EGT's shouldn't be affected much either way(except when on it hard), but have yet to verify this as I just have had setup for last month or so(MAD and injectors). I plan on swapping out MAD ECM, and put stock ECM back in with Van Aaken in just to check, and see variances, but probably won't have chance to do till next spring camping season.
RonA
14
09-04-2007 12:09 PM
sway825
12-08-2004 11:21 PM
smittybuilt
14
01-05-2004 02:42 PM
BAD HABIT
10-26-2003 12:52 AM
