MAAP Challenger Tube Steps
Re:MAAP Challenger Tube Steps
Easy to install, only took about 20 minutes and everything fit good. Wouldn't mind seeing a little less flex in the brakets and mounts but they are pretty good, i just like over kill
I attached a turn buckle to each mounting bracket and attached the othe end to an already existing hole in the rocker panel. This added good support and keeps any vibration down. <br><br>Fiwiki
Your mounting is totaly different from mine that i just put on. I can see where that would give you alot of flex mounting to the rubber mounts. The mounts I got bolt to existing holes in the back of the rocker and to the bottom of the floor. Their are 2 bolts in the back mount and 3 in the front. Looks like they made a change for the gen 3 bodies, and for the good from what I see.
yeah, mounting to the rubber made them them rattle against the rocker panels when you went through a lot of mud, plus there is no vertical adustment which makes them sit close in. does the mounting on the '03 allow for up and down adjustment. That's the only real complait I have about mine.<br>I wish that I could lower them abotu two inches.<br><br>Fiwiki
Their is no adjustment for up and down no. It could be done by sloting some holes and using spacer shims in other I suppose. But the fit and location is perfect on mine, no need to adjust. I might have a chance to get some pictures of them tomarrow depending on the weather. If I do I will post them.
TIM RYDEN
04-25-2005 11:50 AM
Green Giant
12-26-2002 04:07 PM
UTAH
19
12-07-2002 12:43 PM
