M11 Performance Turbo
Old 03-19-2003, 09:13 AM
Hired Gun's Avatar
I was recently looking at a site that sold M11 Performance Turbos. What are they, and what can I expect.<br>I have heard of the 40, and B-1's, but an M11 is new to me. Can somebody shed some light for me?
Old 03-19-2003, 09:33 AM
SjLingenfelter's Avatar
Re:M11 Performance Turbo
Whats the site address? I wonder if its like a Military turbo for something M-11???
Old 03-19-2003, 09:43 AM
DTR Advertiser
Don M's Avatar
The &quot;M-11&quot; is the 11 litre Cummins in-line six engine. It uses one of several HX50/H2E variants. So, the turb is a H2E or HX50.<br><br>Just like the L10 is a 10 litre Cummins and uses the Hx40's.<br><br>Don~
Old 03-19-2003, 12:30 PM
Hired Gun's Avatar
Well Don, which turbo would you recommend for me. I have the stocker now, but am looking for a turbo in the next couple weeks.<br>I see you know alot when it comes to nitty gritty, so help me out. PLEASE
Old 03-19-2003, 03:25 PM
tool's Avatar
I ran an M-11 ona 9spd R.R in a International Daycab tractor last year floating a crop sprayer job to job.<br><br>Boy did it sound sweet! It was a mean sounding truck for sure ;D<br><br>Lots of growl and and turbo whine. I wasn't impressed with the power though. [undecided]<br><br>The truck seemed geared pretty high but still, I thought it'd have more grunt than it did.
Old 03-19-2003, 03:47 PM
DTR Advertiser
Don M's Avatar
[quote author=Hired Gun link=board=7;threadid=12473;start=0#118022 date=1048098612]<br>Well Don, which turbo would you recommend for me. I have the stocker now, but am looking for a turbo in the next couple weeks.<br>I see you know alot when it comes to nitty gritty, so help me out. PLEASE <br>[/quote]<br><br>The Kwikspool B-1 is good choice. Its tough as nails. Kinda like the engine you will be installing a turbo on <br>If you have a 5 or 6 speed the normal B-1 is cool too. <br><br>The HX40 is a good choice but you do give up some reliablility with it. The H2E is stronger than the HX40 but will spool slower and has a kinda weird looking exhaust housing that moves the downpipe location kinda off center. The 40 is cost effective as well as the H2E when compared over the short term but the B-1 will outlast them all and if you plan on keeping the truck the B-1 would be the best overall choice for long term/high mileage use, IMO<br><br>Don~<br><br><br><br>Don~
Old 03-20-2003, 09:16 AM
Hired Gun's Avatar
Ok. Well Don let me throw this at you. I have also located an HX55. Would this turbo be good with my mods?<br>I don't want to hurt the truck. A friend had a new HX55 blow apart a month ago. Is this a problem with the 55 or did he do a major no-no to make it happen?
Old 03-20-2003, 10:37 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Something that you may be interested in from Kurt is his new K.45. It uses a compressor that is about the same size as a B1, but has an impeller shaft thats 1mm smaller. What you'll get with a K.45 is PDR40 spool up (the KwikSpool version is a little faster yet) and the great midrange and topend punch of a B1. With your level of mods, you'd need to externally wastegate, and if you plan on going stronger on injectors in the future, then you'll want to skip by and go to the B1.<br><br>Rod
Old 03-20-2003, 10:50 AM
Hired Gun's Avatar
I am staying with the DD III's because I pull a gooseneck alot. Right now my egts are a problem if I want to let it all hang out. I have done everything except change the turbo from stock.<br>I have looked at prices and most of the turbos I find are an arm and two legs. I have looked in the classifieds, and other sites and found some reasonable turbos. Enterprise has the <br>HX40 for a great price, and I have found the HX55 from a classified. I cant PM you because incorrect parameters at my work computer. I will when I get home. I will call Wildcat Diesel and get some prices. Thanks for the help.<br>Jared
Old 03-20-2003, 11:49 AM
Hired Gun's Avatar
Ok Push Rod. What about the HX40/HX35 Hybrid? Tell me more.
Old 03-20-2003, 02:12 PM
Push Rod's Avatar
Thats an entry level 'charger that we keep around for the 350 - 380 pony crowd who wants to keep temps down low. Its an HX40 compressor (not a 35 compressor honed out to accept the 40 wheel) mated to an HX35 cartridge and turbine housing. Pretty tough little turbo, but it pretty much runs out of oomph at the 380 pony level. You'll be past that mark with your TST/EZ and 3's. I wouldn't recommend it for your setup.<br><br>Rod
Old 03-20-2003, 02:20 PM
Hired Gun's Avatar
Thanks so much. Well I will call about the other turbo you mentioned from Wildcat! ;D
Old 03-20-2003, 02:34 PM
Battering Ram's Avatar
Rod:<br><br>How much would one of the HX40/35 hybrid chargers be without the exhaust housing? I think it would make a great secondary on my twins.... Any comments?
Old 03-20-2003, 08:08 PM
Push Rod's Avatar
Unfortunately, I can't buy the things without an exhaust housing. I'd suggest buying it with the non-wasted housing and then selling the housing (someone will snap it up without any trouble). Keep in mind though, that without the housing its just your basic 40 compressor mated to an HX35 cartridge. I guess you could put your stock 12cm wasted housing on it...<br><br>Rod
Old 03-20-2003, 11:18 PM
Top's Younger Twin
Scotty's Avatar
[quote author=Hired Gun link=board=7;threadid=12473;start=0#118471 date=1048191657]<br>Thanks so much. Well I will call about the other turbo you mentioned from Wildcat! ;D<br>[/quote]<br><br>HG, since I am REALLY biased...you need a Scotty Air II...I did not see any upgraded air intake in your sig.<br><br>At least when I read it...
Quick Reply: M11 Performance Turbo
