Lukes link--track bar woes
I hate the steering wander and play in the steering wheel...whats the most efficeint way to help this issue. Luke's Link...or the steering stabilizer kit that bolts to the frame and steering box?
ive noticed i have about 1/8 of a turn of play in the steering wheel when driving at 65 mph and i cam constantly fighting the wheel...but the truck still drives straight, the wheel just has so much play...also notice that its very difficult to turn the wheel when sitting still. Is this just because of the weight on the front tires....or could i have a power steering issue as well?
thanks in advance for the help!
Get under the truck and have someone rock the wheel back and forth....you need to know exactly where the movement is before you can fix it. No sense in throwing parts at it....
getblown5.9:
"Cowhand" is giving you some good advice on checking the ENTIRE front end before throwing parts on the truck! When I got to point you are on my 1996 Dodge CTD, I ended up having to replace ball joints, upper and lower control arms and the steering shaft! But, I can tell you that the DSS Stabilzer Bar works GREAT and definitely made a BIG difference in my truck! I also installed a "Lukes Link" and it stiffened up the steering feel alot. I did this all at once and my "wander" is completely gone. However, I have a friend who just installed a DSS on his 2002 Dodge CTD at about 50,000 miles and he said it completely took care of the "wander" he was beginning to have.
John_P
John_P
Well, since these trucks are known for weakness in the trackbars, steering shafts, ball joints, etc. you need to follow Cowhand's advice and SEE WHAT'S WRONG.
It may be track bar play (at the frame), or steering shaft play.
Heck, it may even be your steering box. If it IS the box, try www.pscpowersteer.com
jlh
jlh
I used to have HORRIBLE steering on my 98.
I've installed a: Luke's Link, Borgeson steering shaft, AGR steering box and will be installing a DSS steering stabilizer when my hardware kit comes in.
The steering is MUCH improved but I'm looking forward to seeing how the DSS will do.
Dealer replaced my track bar and intermediate steering shaft under warnnity. Then I added a DSS steering stabilizer. Last year the second OEM track bar was shot and I installed a DSS 3rd Gen track bar conversion. Now, for the first time ever, I can let go of the wheel and the truck will track straight. Even after adding the KORE "lift kit" the truck still tracks 100% true.
IMO, If you need a new track bar the 3rd Gen. conversion is the only way to go.
Originally posted by Dr.Kayak
.....IMO, If you need a new track bar the 3rd Gen. conversion is the only way to go.
Yup, me too. It would be the last time you have to look at the track bar.
J-eh
Frankly, everything under my front end had slop at 20K miles. Nothing worn out, just getting there faster than I wanted to see.
So I put on the following:
Borgson intermediate steering shaft
DSS
'03 trackbar with Solid Steel bracket
dual steering stabilizers
quad shocks with KYB Monomax's
D25 springs
Michelin 265's
corners better than my old 'Vette. I'm almost not kidding.
DSS
D25 springs
Michelin 265's
well...i am gonna look at getting an adjustable 3rd gen style track bar because all my steering slop seems to be in the tie-rod end of the track bar.
this is where i need to decide if I get the regular 3rd gen style...or if I go with the more expensive adjustable type
You're much better off going with this...http://thurenfabrication.com/stocktb.html
Way beefier, rebuildable, and cheaper than the 03 conversion. Don's been getting 5-10 calls a week from guys wanting a replacement for their 03+ track bar....
The Thuren link you offer has no contact info...for anyone that might be interested!
RJ
