low turbo boost
low turbo boost
I have an 01 3500 dodge dueley have installed edge attitude juice boost fooler lift pump j hook for waist gate air filter and exaust this truck wont go over 20lb of boost any help would be appreciated. JERRY?
as far as i can tell your better off with a mechanical style boost fooler like the one i had on my stock turbo .. you can make as much boost as you want.. nto saying you wont blow it apart at over 40lbs of boost tho
On the exhaust manifold look to see if there is any carbon built up around the mounts to the engine. If you lose a gasket you can see a build up. Did you unplug the boost fooler? For the intercooler you have to be able to pressurize it to see if it is leaking at all. Any codes on the truck?
Thanks for everybodys help, found time to work on truck today, tighened clamps checked exaust for leaks un pluged boost fooler from edge and went from 20 to25lbs, guess rest of loss in waist gate area maybe work on that next thanks JERRY.
In the Attitude Configuration there is a max boost setting. Are you sure this is not set too low? I used to have a Juice. I once had it default to a maximum of zero psi boost and the truck would build no power. It would be good if you could pressure everything up from the compressor housing on the turbo all the way into the engine to see if you may have a leak somewhere. You may want to make sure your wire tap on the injection pump is good and right. What kind of boost fooler are you reffering to? If you have no exhaust leaks then you may be correct in that the wastegate may be leaking exhaust past it. With your Juice on level 5 I would think you should be able to make30-35 psi boost. Make sure air cleaner okay.
Yesterday worked on truck, took turbo snd housing apart found small crack in waistguate seat so i welded it shut taped and pluged turbo, now have 32lbs on #2 tow setting. hope every thing will be alright. reply if i screwed up THANKS FOR THE HELP JERRY?
Moobesor
02-23-2008 09:57 AM
