low boost numbers
low boost numbers
well im a little curious about my turbo, its a 71 series 64/14 and i have lasercut dvs, 435 injectors and a #4 fuel plate for fuel, i can't seem to get more than 48psi out of my turbo, the wastegate is adjusted all the way and i have a boost elbow put in, but only gained 6 psi from all that, why cant i get any more boost??? with all that fuel i should be boosting more, i was told the efficiency range for this turbo is 55psi any one have any ideas?? thanks
jason
jason
I sure dont. LOL but maybe yall can kill two birds with one stone on this tread. With what is in my sig, i am only boosting 20. should I be boosting more than that?
Thanks.
Trapper.
Thanks.
Trapper.
jason
Remove the boost elbow and insert a 1/4 inch pipe plug and see what happens. I only see 30 lbs with my 64 and it cleans up nicely at nearly 500 hp. Do you see smoke at full boost?
No I didnt buy the ez new, i bout it from a friend for a $100. I can see a little hase of smoke at full throttle. The only reason i ask, "is 20 not that much" is bc i had a friend install it and it was his first time doing it. I should have done it myself , But i dunno. i am ordering the elbow.. I will c if that helps.
Trapper
Trapper
Trapper
Trapper
~Nick
on the dyno i didn't stop blowing smoke until i let off, turbo wouldn't go past 44psi, on the road i blow a little smoke at 46psi but it doesn't totally clear up.
jason
well i plugged the boost elbow hole with a bolt and ran the truck, but i still couldn't get over 50psi, mostly ran to 49 and stayed, and im still blowing smoke at 50psi, not tons but enough. need more air
jason
jason
sCreamin400
11-02-2008 01:46 PM
Moobesor
02-23-2008 09:57 AM
Capp35
03-26-2006 12:43 PM
