Love my Edge Comp Drag
WOW! Installed the Comp Drag last night and what a difference! I had no idea a "box" by itself could add so much dang power. I need to get a downpipe and exhaust before I do anything else. EGTs are a little high and quick to get there. The FP is pulling down to about 5-6 at WOT. I'll probably install the BD fuel setup before too long (cheaper).
Just thought I'd add my .02 and say the Comp Drag is the FUNK!
Conn
Conn
Administrator / Scooter Bum
If you don't have gauges, you need to have them next on your
Stuff-I Really-Gotta-Have list.
Especially EGT & Fuel Pressure.
ask DieselDude4X4 how important monitoring EGTs are.
Melted aluminum pistons aren't a pretty sight.
Anyone know the HP rating on the DRAG Comp?
I know the TST PM3 COMP is listed at 180 hp and causes some surging problems by calling for more than the VP44 can deliver (at higher settings).
Does the Drag Comp have any similar problems?
RJ
RJ
RJ
RJ
Edge claims 150 and I think from what I have read its pretty close to that.
I will be having my Comp reflashed in Sept and we will see.
Originally posted by ratsun
_________________________
Originally posted by G-NOTE
If I go w/ the comp, other than gauges, strightpipe, and BHAF w/ Heatshield... What else do I need???
RJ
I got straight pipe 4" I think... NO cats, NO muffler
I guess I need to get 4" downpipe???
I just put in a dodge fatory clutch , and as far as TURBO I'm not ready for that...
Unless it is a must have???
RJ
RJ
G-Note... RJ's probably right on the clutch since you have a 6sp.. not sure what they put in there.. but the stock 6sp clutches are a little weak... Turbo... well.. to get the most out of the box.. yes.. but it can wait... I have the Comp and DDIII's (100hp) and still the stock turbo..
Bryan
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
rockjeep73
03-25-2005 03:34 AM
MoreSmoke
01-07-2004 09:40 PM
