louder exhaust
louder exhaust
I am currently running a rip rook 5" shorty exhaust with muffler delete pipe, hx 40 dp,and a 7"x24" tip. It is starting to sound a little quiet to me, is there anything out there or any way to make it louder?
Yeah, what mopar said, cut a hole it the hood and put an elbow with about a foot to three foot stack out. Could always run it into the truck....
i got a 4 inch straight that comes out before the rear tire and its waaaaaaaay louder than anyone wants it to be. the bigger the exhaust the quieter is what it seems to be.
if you are good at fabbing stuff up you could take some sheet metal and shape it into a big bass air horn and put it on the end of the 7" tip and your 5.9 will be the air compresser
I went from a 4 inch turbo back straight setup to a 5 inch turbo back straight setup and she got significantly quieter, definitely deeper but much quieter. Must be a volume vs. velocity thing...
i cut off the cat. and stock muff. ran 4" from turbo stright back. i put a 4" in and 4" out cherry bomb muffler on and a 6" stainless tip out the back pass side. sounds good. the rolled end on the tip makes a difference in the sound also
06 dually
ats exhaust manifold
k&n filter & tube
sun cost multi disk , low stall torque converter& valvebody
some trick work on 48re tranny
radicalray
in michigan
06 dually
k&n filter & tube
radicalray
in michigan
JVDodge
24
05-11-2008 09:39 AM
DUKCALN
04-14-2008 06:16 PM
