Loping Cummins?
Loping Cummins?
I was sitting at a light yest. and I heard the Cummins next to me loping away like it had a nice sounding cam in it. I've heard that a cam won't make our trucks lope at idle or anything. How did he do it? Anyway I could make mine do it short of playing with the throttle at the light. I've been known to tap the throttle and make it sound that way. ;D
Re:Loping Cummins?
SuperMentals use to lope at idle, not so sure they do now though. ??? <br><br>Did he have gauges? If so then it was more then likly injectors, it not then who knows. <br><br>Andrew
Re:Loping Cummins?
big injectors supply so much fuel down bottom that there's little air to supply it with (no boost of course). imho, a 12valver sounds better loping with big injectors (more aggressive).
Re:Loping Cummins?
There are some companys that will special gruind cams, I have seen them in larger detroit diesels , not usually on the street I have spoken with a freind of mine that seen some one up hear with that same setup in 12v dodge truck ??????????? don't know what sort of rpm he's hitting
Re:Loping Cummins?
was it a 12V or a 24V? You can get a *romp-romp-romp-romp* kind of lope out of a 12V with some good pump work... my dad's truck's idle does it very well when it's cold . My supermentals have a pretty good lope at idle, but it's gotten a lot better since I added the DD box on top of the PM3 :'(. I'd guess an ever bigger injector would do it even more.
Re:Loping Cummins?
[quote author=banshee link=board=7;threadid=7261;start=0#69839 date=1037801425]<br>was it a 12V or a 24V? You can get a *romp-romp-romp-romp* kind of lope out of a 12V with some good pump work... my dad's truck's idle does it very well when it's cold . My supermentals have a pretty good lope at idle, but it's gotten a lot better since I added the DD box on top of the PM3 :'(. I'd guess an ever bigger injector would do it even more.<br>[/quote]<br> I started to mention your truck yesterday, but I couldn't remember if you were piggy-backing boxes when I saw you at Keith's house. <br> Let me tell ya fellas, Johnner's truck has or did have a definite "LOPE" the last time I heard it. ;D What got my attention, was when you started flippin switches in the cab (or whatever you was doing) that made the entire truck, (exhaust and motor) change its tune. It reminded me of a cammed up gasser more than a diesel. Sounded Sweet! ;D <br>That was right before he lit up the back tires (Major Roasting) and engulfed the nieghborhood in smoke. When the smoke cleared,,,,,,,, nothing but two sticky black streaks of rubber remained ;D ,,,,,,,,,,,,,,long,, loonng,, loooonnngg streaks!
Re:Loping Cummins?
Hey dennis... that's was before I had the box piggybacked. I really liked the way the truck idled without it, but it does run better with it. That extra timing calmed down the idle quite a bit, but it still chops pretty good, and sometimes it does it more than others. The adjustment was with the remote on the PM3 ;D. <br><br>Also, BigBlue, larger fuel lines from the pump to the injectors will give a very lopey idle. It's more noticeable on the 12Vs because their injection pressure isn't as high, but both engines will rock the truck at idle with bigger lines.
Re:Loping Cummins?
I notice that after installing the EZ, mine lopes when the exhaust brake is activated at idle. It does it for about 3 to 5 seconds then evens out.
Re:Loping Cummins?
That's what I thought 98. It was a 24 valve. My buddys Stang lopes very nicely (has trouble idling) and I love that sound. Buddy's Camaro does the same. I guess I'll have to wait for the tranny before mine will lope. :'(
gpshemi
32
01-24-2011 09:41 PM
rage_blue
13
04-05-2009 11:47 PM
