Loose Steering Fix
Loose Steering Fix
Found this thread on the TDR. Looks pretty interesting. Another great product from sunny Saskatchewan!! ;D<br>Steering Fix
Re:Loose Steering Fix
My truck suffers from the "loose steering" problem. I will be the first to admit that I have no idea what causes it. I installed a Luke's Link on the trackbar which seemed to help a little bit. Exactly what does this guy's device do to help with the sloppy steering?
My uncle had this problem and it was the steering shaft itself. The one that comes out of the firewall to the box. It was replaced under warranty. It seems to wear at the slip yoke. Mine also has this problem.<br><br>Mike
There is always this place.<br><br>http://www.borgeson.com/<br><br>My complete kit, (shaft, coupler) was around $200. One of the better investments for my truck. Took care of the wonder steer all together. <br>
DieselDave<br>I think it takes out all the play from the pittman arm shaft coming out of the steering box. It looks like it bolts to the frame under the swaybar mounts. I've never seen it before but it looks like some guys are pretty happy with it. I guess it'd all depend on how much slop you have in your pittman shaft.
I like the concept but I already ahve a front mount receiver hitch on the truck that uses the sway bar mounting holes. this probably won;t go on then.<br><br>Don
Sounds like it's just what I need, but I have the snow plow mount frame. I've contacted them to see if it will work for me. BTW, the Borgeson steering shaft, and new Moog track bar have done little to correct my steering wander.
v8hunter
12-01-2009 01:21 PM
Leaky Gasket
08-14-2008 07:17 AM
