Loose Steering
DTR's Cow Boss
Loose Steering
So today finally had some room in the shop to nudge the truck in there and commenced to adjusting the new steering gear box since i had put the new one on it was really crappy steering all loose n mushy but better than before and being a new box i figured i should not have to adjust it. Now it steers like a vette again So for any one with steering wheel play start there first and go to the majors once you started here.
P.S. Check your oil pan bolts as i found mine were loose at the back of the pan while i was under the truck
DTR's Cow Boss
You remeber while back when I was talking too you about psc and i heard they were good an such well turns out there not LOL I went with just a napa box and all is good. My dss is on my xmas list.
DTR's Cow Boss
My box you could grab the wheel n go to the left a bit and bit to the right it would not follow so i knew it was too loose after i fixed it i about ran it to the shop wall i forgot what tight steering felt like LOL
DTR's Cow Boss
ya the nut is 5/8ths the allen i aint sure i just put a bunch on there tell one fit but i just did it little by little each time driving it tell i found were i liked it
DTR's Cow Boss
It works the best to do it from under neith its a major P.I.T.A. to try to do it from the top you cant get all your arms n wrench an allen wrench down there
DTR's Cow Boss
The kicker for me was when I relocated my breather i just made a longer hose and tied it off on the fan shroud so it dumpes beside the steering gear so i got all this road dust n oil mix in my eyes
