looking for pics of lifted 2500`s
Originally posted by TxDiesel007
Ill chip in
My truck has a 2.5 inch lift with 285 good riches, mind you its a 12V, much shorter than most 24V's and sits at minimum at the same height as a 24V. From this pic i know i could easily fit 305's as this picture would show...
https://www.dieseltruckresource.com/...cat/500/page/1
But i would suggest at least another half inch, i have had 305s on there and the clearance is DANG CLOSE...
here it is again from a slightly farther stance..
Tx
Ill chip in
Tx
Originally posted by Dave88LX
Do they make a 12" ball drop?
Found a couple places that would fab one up,
but for quite a bit more $$ than the 10inch drop I picked up for $30.
Spoken of in the Other section.
phox
Originally posted by BigBlue
4.5" Skyjacker with 315/75/16 Nittos. If all you want to run is a 305 then just stay with a leveling kit. A 305 on a 4" lift is gonna look funny.
I have a 4" lift on my 99 with 36" PJ's. I would NEVER lift the truck again. I say MAX33" tires next time. The bearings ujp front can't handle the added weight. Then you have a ball jointed 60 (POS). I say keep it stock.
dIma
dIma
What would tire size have to do with wheel bearings? Not much lol. I would say the normal backspacing of around 4.5" on most 10" wide wheels would have a lot more to do with bearing wear than tire or wheel diameter. I sold my 10" wheels and got the 9.5" Welds with 6.25" backspacing which is pretty close to stock. They tuck in better and IMHO look a lot better than my 10" wheels did. Truck seems to drive a little tighter with them as well. I ran Nittos on my 10" wheels and they are nice. They did wear pretty quick. They were getting pretty thin by 12k miles. We'll see how the Toyos do this time.
dIma
dIma
Then again, I got 180K out of a stock trans before I burnt the lock up clutch off, running about 300HP and turning those 36-37" tires.
Guess them Mexicans know how to build trucks...
