looking to buy a 24 valve in next few weeks... ?'s
Old 10-25-2010, 10:55 PM
ZombieSoldier's Avatar
so im looking to buy a 24 valve here in next few weeks.. and i am looking to spend approximately $1500-$2000 on best bang for the buck performance parts. where should i start? its a 2001 cummins 4x4 with an automatic.. bone stock. this truck will be used as a daily driver/play toy, with occasional towing.
Old 10-26-2010, 05:06 AM
wurkenman's Avatar
Start with a set of gauges. Then save a little more and replace the transmission so when you start the bombing process, you will not be left stranded on the road. If not get a good set of injectors, exhaust, intake, and a programmer. Don't be surprised when the trans fails though.
Old 10-26-2010, 07:35 AM
really its like that? thats not real re-encouraging.... what up with the tranny? what should i look for in a replacement tranny?
Old 10-26-2010, 07:37 AM
the mods you listed above, would make what kinda power/torque?
Old 10-26-2010, 07:51 AM
Clunk's Avatar
Check this pretty close,
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
Old 10-26-2010, 08:04 AM
what does the 53 block have to do with the topic? dont get me wrong its good reading and good to know
Old 10-26-2010, 10:39 AM
DIESELWRKS's Avatar
there is a chance that the truck your looking at has a 53 block.
Old 10-26-2010, 12:34 PM
Hodge's Avatar
Most any auto will fail when that much torque is being put through it. Ford, Dodge, Chevy- all of them have marginal stock transmissions. If you want the most out of your truck, it will need a stronger transmission.
Old 10-26-2010, 01:48 PM
Midnite's Avatar
You can safely do stuff like an Edge EZ, intake and exhaust mods without worrying too much about the tranny. Just the addition of a tranny temp gauge will help it survive because you can monitor fluid temps and keep them in the sane range.
On an older 1992 truck I did injectors, pump mods (which basically equate to the Edge EZ on the 24 valve), intake and exhaust, and I never touched the tranny except to do normal servicing. You'll quickly learn what driving techniques kill the transmission and you won't do them. That's the biggest thing right there.
Old 10-26-2010, 06:04 PM
wurkenman's Avatar
462hp and 969 tq. I took the tranny out in mine 5 weeks after installing the Adrenaline. IT HAPPENS.
Old 10-26-2010, 10:42 PM
thanks guys! any other suggestions?
workman that is definitely impressive.. i am thinking of buying a whole new tranny what would yall suggest for the tranny?
Old 10-26-2010, 10:57 PM
also what about a 6.7 vgt on this ram? with the mods suggested above or even stock, how would this truck perform?
Old 10-27-2010, 05:03 AM
wurkenman's Avatar
If you can't get one built locally. Here is the Best option out there.
http://www.goerend.com/
Old 10-27-2010, 09:15 PM
8UPRACIN's Avatar
The first thing you need is a fuel pump!! Everyone always over looks fuel pressure for power. I would get a pump, intake, exhaust and maybe a small programmer/chip. An Edge is nice because it has gauges all built in to monitor your tranny temp, EGTs, Fuel, Boost and like 40 other features. Just be smart when you get your power increased. If you run around hammering it all the time with the chip cranked up dont be surprised to be having to get a tranny built within a month. If your smart and drive it nice it should hold a while till you get it freshened up with a good valve body, convertor and whatever else you decide to do it. You could spend $3k-$8k on a tranny depending on the power level you want to go to. Good luck and have fun. Chris
Old 11-08-2010, 12:46 AM
catnfool's Avatar
I just bought a Suncoast coverter (it's even a single disk, I think) and went with it on my 12v about a 80k ago, and I am hard on things It has worked well for me- 4 or 5 good tranny builders out there- use the search and you will be impressed!!
Quick Reply: looking to buy a 24 valve in next few weeks... ?'s
