Looking for 1" rear blocks
Anyone know where I could score some 3/4" to 1" rear lift blocks? something easy to stuff under the existing block?
Ive got a 3" lift in the front, now I need to raise the back a tiny bit to level it out.
Is this something I could fab myself with some thick alum or steel bar stock? Im assuming you need a slight angle to keep the pinion angle right.
I had the same issue after doing the leveling kit.When you parked the truck it looked nose high at the times and all I did was add the SkyJacker D25 coils.So after months of griping about it I went and added a leaf to my rear set of springs which placed the rear back a tad higher than the front and improved the way the truck looked a bunch.Total cost for that was just over $150 with longer u bolts for the rear.......Andy
What I did on my truck was got some 1" thick 2.5" wide steel.
Drilled a hole in the center and got a new spring pack center pin. Bolt the bolt into the spring pack, and than reinstall the stock block.
I'm not sure if the factory U bolts are long enough, I had some made a while back so they were plenty long.
Off Road Design. They make zero-rate add-a-leaves which is exactly what your looking for. http://www.offroaddesign.com/catalog/Zero%20Rates.htm
MTC
09-07-2010 06:59 PM
PEAKSTRYDE
10-11-2007 05:20 PM
Katmandu
01-16-2006 09:30 AM
